Daz studio unable to locate texture files
(sorry for poor english)
Out of nowhere daz studio act up and suddently cant locate texture files when I try to load a scene(duf file). The texture files are right  where they are, but daz stduio just won't load.
Theres no problem with textures when loading individual assets, I can't cant load a full scene. Any help would be appreciated.
1066 x 882 - 356K
840 x 618 - 73K
  • leo_bearleo_bear Posts: 44
    Seems like ds is having trouble locating my J drive. What should I do..
    1821 x 548 - 81K
  • What are you content directories set to - Edit>Preferences>Content tab, click the Content Directory Manager button.
    Hi Richard, Most of my assets are installed in my external drive(J). ds for some reason just can't locate them.
    452 x 177 - 13K
    There seems to be more folders under "Daz Studio Formats" than just those three, which are they?
  • frank0314frank0314 Posts: 15,116
    edited August 2021
    This is probably a stupid question but did you check to make sure the J:/ is operational and recognizable and it didn't go bad?
    Edit to add: What product are you trying to load?
    Post edited by frank0314 on
    The other folders are mostly nsfw third party assets. I believe those don't have anything to do with the problem.
    262 x 81 - 4K
    Yes they are operational and acessable.
    You are still not showing them all, I'm looking for possible nesting
    edited August 2021
    Go to Content DB Maintenance>Re-Import Metadata. Just to see if there is some form of glitch that is causing it. It won't hurt anything.
    edited August 2021
    It is a little bit messy but there you go. :)
    462 x 1417 - 61K
    Post edited by leo_bear on
    And what's behind doors 5 and 6, ie. "New Content Set" and "New Content Set (2)"?
    Theres nothing in them. I created by accident and forget to delete them
    364 x 350 - 11K
    Thanks for the advice. I tried to re-import metadata and it is not helpful.
    It is not the product's problem. Loading indiviual products are fine, but loading a scene it will say that it is missing textures. Mannauly Relocating all the textures in a scene is time consuming and not an effeicent way to solve the problem. Any other ideas?
  • Richard HaseltineRichard Haseltine Posts: 111,984
    edited August 2021
    Only the Current Set matters in any event.
    The thing is, the path in the error is only the relative path in the file - the fact that is is listing folders in front of the Runtime, which would be the starting point, does suggest that at one time there was another folder - prsumably the root J: drive - selected as a content directory and the files were saved while that was true.
    Can you load content, rather than your own saved scenes?
    If you mean content as products, yes I am able to load them with no problems. The only problem I have is with the saved scene.
    OK, then that is probably what I mentioned - when you saved the scene you also had a second content directory seelcted which contained the real one, and instead of recording the location within the real directory DS recorded the location within the parent directory - which added the unneeded folders. If you expand the saved scene file in its folder (using the Batch Convert pane in DS or an archive tool such as 7Zip) and open the result in a text editor a search shoudl find lots of entries containing
    work/daz3d/my%20daz%203d%20library/
    if you search and erpalce those with nothing and save the result as a .duf file (don't overwrite the original in case of accidents) then I think you will find the scene opens OK.
    Sounds good, but theres hundreds of lines for each scene file. May i ask is there a script that can do the work?
  • Just use search and replace in your text editor (I would not use a word processor for this). Use search to see if you do have lines containing that string, which I thinkis correct, and if you do then (working on a copy) do a replace all. If it is the issue a good text editor will let you chnage multiple fiels at once.
    Notepad++ is a good text editor for that sort of thing.
  • SpaciousSpacious Posts: 481
    When you get stuff loading right again, you may want to go in and clean all that up too.  I've never noticed any troubles from having even as many as 10 library folders, but with as many as you seem to have, I would imagine it's slowing you down.  DAZ tries to treat the entire content library as one big folder and scans through the entirety of evrything each time you load an asset.
    Thank you! This text editor is really helpful.
