Daz crashes with Dynamic clothing
rickfoxxx74331700rickfoxxx74331700 Posts: 186
Daz crashes when I try to open a saved animated drape scene, or if Daz open, Daz freezes when I try to edit the pose of the model which has the dynamic clothing.
That issue only happen with saved animated drape scenes.
I'm using the latest version of Daz.
  • Richard HaseltineRichard Haseltine Posts: 111,838
    Any dynamic clothing or only certain pieces? Which version of DAZ Studio (Help>About DAZ Studio) and which operating system?
  • rickfoxxx74331700rickfoxxx74331700 Posts: 186
    Thanks for responding.
    Until now that only happened with Pregnoir from http://www.daz3d.com/dynamic-nightwear-for-v4 but my issue is the same as babel25 had on this thread http://www.daz3d.com/forums/discussion/20478/ with another dynamic clothe.
    Daz Studio 4.7.0.12 Pro Edition 64 bits
    Windows 7 Ultimate SP1
    It might be worth reinstalling, just in case the file has become corrupt in some way. If that doesn't help I think you should report it as a possible bug, via a support ticket.
  • Wallace3DWallace3D Posts: 171
    I found the best solution to recover the File that has animated dynamic cloth that causes your file to crash on open is to go to \My DAZ 3D Library\data\auto_adapted\ and look for the folder that hold the name of the Dynamic cloth
    for example the M4 scoop Neck tee and change the folder to .old (Scoop Neck Tee_6784_Object to Scoop Neck Tee_6784_Object.old)
    then reopen the file in Daz Studio. it will give you an error message that it is Missing Files.
    remove the Dynamic clothing or drapes that you have animated and save
    I have found this to be the best solution on recovering Files that are in conflict by the dynamic clothing that is animated
    just dont forget to change the *.old folder back ;)
    I hope this helps
