Poke-through.
Cparice HD for Genesis 8 female, with most of the HD details applied
Linda ponytail hair for Genesis 8 female, base color 9
London Lo0ok full outfit, with random materials selected
No matter what I do with the sliders for nipples, Caprice pokes through this shirt. I've tried several others with similar or worse results- sometimes the whole breast pokes through.
Does anyone have a favorite YouTube video on how to work with clothing? Right now my skills end at point, click and swear.
1020 x 1020 - 152K
    There are a few things you can try. Firstoff, check the clothing for a smoothing modifier. if it doesn't have one, add one (edit - figure - geometry - add smoothing modifier) and make sure it collides with the figure. This cures 80% of issues with pokethru. If it already has one, play with the settings, both smoothing and collision to see if you can make it go away.
    next, check the clothing for any morphs. Some clothing items will have an expand all morph which will also fix this kind of issue
    next, if it is a simple cothing item like a tshirt, you can always add a dforce modifier to it (simulation settings tab - the little icon to the upper right - dforce - add dforce modifier dynamic surface) and run a simulation.
    next would be to hide the polygons that are showing with the geometry editor (select the geometry editor tool, then select the polygons that are showing, right click, select geometry visability and hide the selected polys.
    You could also try adding a deformer to move the parts of the shirt, but that takes lots of practice and doesn't give the best results IMO
    there is also a push modifier, but it can create artifacts with the clothing you are using it on.
    There are a couple of poke thru addons in the store, but i never really found them any good. Hope this helps
  • Thank you!
    If the nipples poke through I go to the figure and add a low value nipple morph, say 1%, this should add that morph to the clothing which you can use to control that area of the clothing.
