install manager installation of DAZ studio
firestorm31
just recently installed the Daz install manager.
while it was installing stuff on my drive, I went to eat my supper.
when I got back, it was already downloading the files and installing them. but it was being done on the wrong hard drive that being the C: drive. ugh!.
I had to uninstall it and re-download it and have it installed to the D: drive.
what a time waster!!!
what went wrong?
Post edited by firestorm31 on
There's a check-box at the bottom of the "Ready to Download" tab -- uncheck it if you don't want the items to be installed as they're downloaded.
There's a check-box at the bottom of the "Ready to Install" tab -- uncheck it if you don't want the zips to be deleted after installing them.
I assume you've found out how to change the install locations.
Path locations; yes, that I did.
I do have questions tho.
I found this still on C:
C:\Program Files\DAZ 3D\Content Management Service
Is this an artifact where the DIM installed part of it on the C: drive?
the install manager is on D: drive.
That gets installed when you install the Install Manager, so it happened before you set the path, using whatever your system says the default application install path is. If you installed PostgreSQL CMS then you can uninstall the old Content Management Service; if you haven't, there's an installer for the old Content Management Service here:
C:\Program Files (x86)\DAZ 3D\DAZ3DIM1\cms
(or wherever you installed the Install Manager) -- I believe if you uninstall the old Content Management Service and run that installer manually you can change the path.
I do have the postgresql cms installed.
I have the dim installer on D: drive, the CMS directory is also listed under there; just the *.exe. in the cms directory.
if i understand you correctly, uninstall the one on C: drive, and run the installer on D:? will this change anything?
I have the dim installer on D: drive, the CMS is also listed there; just the *.exe. in the cms directory.
Since you have PostgreSQL CMS installed you can just uninstall the Content Management Service, no need to reinstall it.
ok, old cms is uninstalled and no longer in the program registry.
what does cms do?
Smart Content
Searching
Categories
Products list in Content Library
Tags
Super-conforming
Presets in Lights/Cameras/Surfaces panes
Labels on icons showing type of file (Materials, Actors, etc.)
ok thanx
