Transfer utility stuck at 22% every time
So I just spend 2 days making a lovely garment in Marvelous desginer, and saved it with the UV correct and thin and welded setting, and Daz studio size settings.
My problem is when I get to Daz Studio, to fit the clothing, I do the Figure setup, copy the gemority the from the selected figure, the figure is same size and shape as the one in Marvelous Desginer. I then import my OBJ. and and delete the bits i don't want and delete the figure, so i am left with just the garment, with correct parts. I have apply subD and Launch Transfere Wizard ticked, as I always do, and it works fine. but soon as it hits 22% it freezes and does nothing. I have had this problem but the work around, is not working this time, and its just crashing. I have read the forums, and it would seem that no one is wanting help this, other than show us your logs and then we tell you the logs are wrong, but no offer any support or advice on how to fix the problem in first place. there is like 10 posts like this, and none of them seem to have any solutions or advice, just asking for logs. I get that it helps, but seriously, why it the transfere utlity crashing the whole program rather than just saying failed!
I have spend 3 hours trying to fix the problem and still can''t find a solution, can any one help? maybe support, might be able to help other than asking for logs.....
I'm not sure i follow the workflow - if you are using the Transfer Utility then there is no need to use Figure Setup at all. Have you tried just importing the OBJ and running the Transfer Utility?
