Nerd3D's Spray Tool
MortzeMortze Posts: 186
Hello!
Is there any tutorial or guide of the Spray Tool http://www.daz3d.com/the-spray-tool ?
I can't get to understand how it works...
  • fixmypcmikefixmypcmike Posts: 19,739
    It comes with a tutorial -- by default it installs to the Tutorials folder in your content folder, which you would view outside of DAZ Studio/Poser.
  • MortzeMortze Posts: 186
    I saw it. But can't make it work.
    I load the sprayer, position it to where I need it, and the move the Spray dial, in the Simulation parameter, and nothing happens. I can't see any drops or spray. I move the dial to 10, 20, 30, 50, 70% and nothing happens..
  • kaotkblisskaotkbliss Posts: 2,918
    Is it something that maybe you can only see after rendering? Try doing a spot render on the area where your spray should be and see if it shows up.
  • airboss1airboss1 Posts: 68
    Hello!
    Try opening up the timeline to see it work.
    I do that.
    I press play and the Spray dial go nuts. Anything I change on dials go nuts - seems normal like it is on a loop from timeline animation.
    But on my viewpoint, no drops, no shower, nothing.
  • Nerd3DNerd3D Posts: 19
    You're using the wrong version. The poser version absolutely will NOT work in Studio and the Studio version absolutely will NOT work in Poser. If you load the wrong version for your application it won't do anything.
    Seems that was the issue. Such a noob! lol
