Geografts and GeoShell interactions
Hello,
I have a problem with my Goeshells no longer covering the surfaces from the geografts on my figure, only the elements from the base figure.
It worked correctly until some time ago (some days ago max) so I'm thinking I may have changed a setting mistakenly (though I have no recollection of doing so).
It also feels like the problem comes from Daz itself rather than the specific content since it happens on every figure I try it on, and even older saved scenes are suffering from the same problem.
Do you guys have an idea of what might be happening ?
  • I create geoshells for the base character and then create geoshells for the geografts. This can get complex and sometimes the geoshels turn white as the parameters sometimes shift. This has always been my experience. I save a lot and if something goes wrong, I open the last saved version which I find is much easier than checking the entire body's shell settings. Hope this helps
  • FenixPhoenixFenixPhoenix Posts: 3,247
    zillahenoch said:
    Hello,
    I'm not experiencing this problem, but you may want to select the Geoshell then in Parameters check under visibility. It might be that the Geograft Surfaces are toggled to "OFF".
  • SpaciousSpacious Posts: 481
    edited August 2021
    Sometimes when multiple geografts and geoshels are used together one of them will turn white.  Usually switching the order in which they are attatched to the main figure will clear it up.
    Post edited by Spacious on
