IRAY rend error: CUDA device 0 (GeForce GT 730)
DAZ Studio vesion: 4.9
Graphics Card: GeForce GT 730 only (Driver Version 388.71)
GPU age: 4 years plus
Operation: Rendering
Other issue: financial, i can't afford a new Graphics card right now
More details about the case:
- i have both DAZ Studio 4.9 and 4.12 Beta. but i only use 4.9 for rendering because it has higher output since it is capable of using my GPU.
- i haven't changed any setting for DAZ and my GPU, and it works fine for years until now.
- my routine before i render is i always check in the Task Manager that my CPU, GPU, Memory, and Disk have low percentage for their operations.
- i'm aware that my GPU is a cheap and low level one, but it has been performing well enough before. what i'm rendering is a scene or setting which i have already rendered many times before. meaning my system works fine back then. the version that i'm actually trying to render right now is simpler because i have removed some characters and objects from the original scene. and so i'm totally confused how come my Iray is now finding it hard to render a simpler scene compared to what it can render before?
- what happens is my screen usually goes black for a few seconds whenever the program has already produced some iterations. it will eventually come back, and it would seem like the operation is continuing. but once the render time runs out or when you cancel the operation, DAZ Studio will just automatically close. so you can't retrieve any output. or in some rare case, the operation will manage to complete, but the output is just 11% for 2 hours as compared to what it can do before which is around 40 to 50% plus for exactly the same setting.
so my Questions are:
1) what could be the reason why my GPU or Iray is acting like this lately? is my GPU physically degrading because of its age?
2a) what can i do to make my GPU or Iray perform again the way that it used to? can it be fixed by just adjusting some settings?
2b) or is there already an available Driver for my GPU which supports CUDA processing once again, either for DAZ Studio 4.9 or 4.12 Beta?
here's the file log for the render:
2021-18-10 17:18:40.543 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Emitter geometry import (1 light source with 1k triangles, 1 instance) took 0.00s
2021-18-10 17:18:40.543 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating environment.
2021-18-10 17:18:40.559 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating lights.
2021-18-10 17:18:40.559 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating object flags.
2021-18-10 17:18:40.559 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating caustic portals.
2021-18-10 17:18:40.559 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating decals.
2021-18-10 17:18:40.574 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Using batch scheduling, architectural sampler disabled, caustic sampler disabled
2021-18-10 17:18:40.574 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Initializing local rendering.
2021-18-10 17:18:40.574 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : CPU: using 3 cores for rendering
2021-18-10 17:18:40.606 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Rendering with 2 device(s):
2021-18-10 17:18:40.606 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : CUDA device 0 (GeForce GT 730)
2021-18-10 17:18:40.606 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : CPU
2021-18-10 17:18:40.606 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Rendering...
2021-18-10 17:18:42.261 WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(IRAY:RENDER): 1.2 IRAY rend warn : RTKernel: please check the input geometry (degenerated/inefficient RT hierarchy)
2021-19-10 17:19:27.032 Iray INFO - module:category(IRAY:RENDER): 1.2 IRAY rend info : Initializing light hierarchy.
2021-19-10 17:19:27.360 Iray INFO - module:category(IRAY:RENDER): 1.4 IRAY rend info : CPU: Scene processed in 46.744s
2021-19-10 17:19:27.376 Iray INFO - module:category(IRAY:RENDER): 1.4 IRAY rend info : CPU: Allocated 37 MB for frame buffer
2021-19-10 17:19:27.501 Iray INFO - module:category(IRAY:RENDER): 1.3 IRAY rend info : CUDA device 0 (GeForce GT 730): Scene processed in 46.886s
2021-19-10 17:19:27.626 Iray INFO - module:category(IRAY:RENDER): 1.3 IRAY rend info : CUDA device 0 (GeForce GT 730): Allocated 37 MB for frame buffer
2021-19-10 17:19:27.751 Iray INFO - module:category(IRAY:RENDER): 1.3 IRAY rend info : CUDA device 0 (GeForce GT 730): Allocated 804 MB of work space (1024k active samples in 0.120s)
2021-19-10 17:19:27.751 Iray INFO - module:category(IRAY:RENDER): 1.3 IRAY rend info : CUDA device 0 (GeForce GT 730): Used for display, optimizing for interactive usage (performance could be sacrificed)
2021-19-10 17:19:54.916 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00001 iterations after 74.311s.
2021-20-10 17:20:23.053 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00002 iterations after 102.442s.
2021-20-10 17:20:23.131 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00004 iterations after 102.516s.
2021-20-10 17:20:50.078 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00005 iterations after 129.469s.
2021-20-10 17:20:51.218 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00006 iterations after 130.602s.
2021-21-10 17:21:19.336 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00007 iterations after 158.726s.
2021-21-10 17:21:20.180 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00008 iterations after 159.564s.
2021-21-10 17:21:33.942 WARNING: dzneuraymgr.cpp(261): Iray ERROR - module:category(IRAY:RENDER): 1.11 IRAY rend error: CUDA device 0 (GeForce GT 730): unknown error (while launching CUDA renderer in core_renderer_wf.cpp:839)
2021-21-10 17:21:33.942 WARNING: dzneuraymgr.cpp(261): Iray ERROR - module:category(IRAY:RENDER): 1.11 IRAY rend error: Missing texture node_tex
2021-21-10 17:21:33.942 WARNING: dzneuraymgr.cpp(261): Iray ERROR - module:category(IRAY:RENDER): 1.11 IRAY rend error: CUDA device 0 (GeForce GT 730): Unknown code 0x2AF7 (while clearing cache in core_cuda_host.cpp:147)
2021-21-10 17:21:33.942 WARNING: dzneuraymgr.cpp(261): Iray ERROR - module:category(IRAY:RENDER): 1.11 IRAY rend error: CUDA device 0 (GeForce GT 730): Failed to launch renderer
2021-21-10 17:21:33.942 WARNING: dzneuraymgr.cpp(261): Iray ERROR - module:category(IRAY:RENDER): 1.3 IRAY rend error: CUDA device 0 (GeForce GT 730): unknown error (while de-allocating memory)
2021-21-10 17:21:33.942 WARNING: dzneuraymgr.cpp(261): Iray ERROR - module:category(IRAY:RENDER): 1.3 IRAY rend error: CUDA device 0 (GeForce GT 730): Device failed while rendering
2021-21-10 17:21:33.942 WARNING: dzneuraymgr.cpp(261): Iray ERROR - module:category(IRAY:RENDER): 1.3 IRAY rend error: CUDA device 0 (GeForce GT 730): unknown error (while initializing memory buffer)
2021-21-10 17:21:43.206 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00009 iterations after 182.594s.
2021-22-10 17:22:03.482 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00010 iterations after 202.865s.
2021-22-10 17:22:23.353 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00011 iterations after 222.747s.
2021-22-10 17:22:25.210 Saved image: C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
