Regarding morph
Hello everybody. Installed DAZ3D yesterday. I searched for tutorials which can explain my lack of understanding of morphs, but so far I haven't found a solution to the problem. Sometimes when I load a character I have only a menu to change the parameters of the body , but not to morph it ( Attachment 1) and in order cases by some accident I open the morph menu (Attachment 2). How do I switch between those menus? Thanks !
Images removed; please clothe the figure, switch to a non-textured display or frame the scene so as to hide the groin and, for females, breasts unless those areas need to be visible and textured to show the issue
The menu on the left side is where you can switch between the regions by single click.
In your first screenshot at the left side >Mouth => Real World< is yellow highlighted, that shows all morphs regarding that region.
In your second screenshot at the left side >Actor< is yellow highlighted, that shows all full body morphs.
You can switch there between the diffrent body regions or to actor (=the full figure).
Thank you , but if you see in the first screenshot , on "Actor " there is no arrow. When I use the Region Navigator Tool and Right Click -> Select : Actor and click on "Actor " in the shaping menu no options appear. Only the flowing text "What do to ? 1. Select something from the scene of from the drop down list......"
Maybe there is nothing because you have nothing in there?
If you want the same Body Morphs for Genesis2 Female you need additional products like this: http://www.daz3d.com/genesis-2-female-body-morphs
Or the Head and Body Morph Bundle: http://www.daz3d.com/genesis-2-female-morphs-bundle
And note there is a similar bundle for the Genesis 2 Male: http://www.daz3d.com/genesis-2-male-s-morphs-bundle
Thats one of the reasons why I prefer the Genesis1 Figure over the Genesis 2 Figures. ;-)
Edit: Back to your initial post. Your first screenshot shows the Genesis 2 Female Base Figure.
And your second screenshot shows the Genesis1 Base Figure. The Genesis1 Figure has more basic morphs included by default.
Oh now I understand, thank you very much for taking the time to answer !
