[SOLVED] Dforce Athena Hair for Genesis 8 Females - work without band?
nicsttnicstt Posts: 11,715
edited August 2021 in The Commons
https://www.daz3d.com/dforce-athena-hair-for-genesis-8-females
Does it work without the band?
Not will it work without, but has it be made to also work without the band?
Post edited by nicstt on
  • memcneil70memcneil70 Posts: 6,157
    @nicstt, I loaded the hair without a character, and it and the hairband load as two separate items. I closed the eye of the hairband and the hair seems okay. If you like I can load a character (takes about 10 minutes for me) and then the hair and test it fully.
    Mary
  • nicsttnicstt Posts: 11,715
    I appreciate what you've done; if you get around to it then I'd be interested but 10 minutes to load a character sucks.
    I went ahead, loaded Coral and an outfit, and the hair and removed the band. I found that where it was, there was a distinct area that looked like a part, where the bangs are combed forward and the rest of the hair are combed back and to the sides. So a simulation is running and I will render as soon as it is done.
    edited August 2021
    So here is the hair in a pose from the poses that came out with the outfit I picked. The part is not that bad and looks like it is real. I also noticed that the ears are nicely exposed, which if you want a hair for an elvin character this would be a winner. I also lengthened the hair as far as it would go. I would prefer more options for materials for the headband honestly to allow the hair to be more versatile, but it can be used without it.
    Mary
    900 x 1456 - 2M
    Post edited by memcneil70 on
    Thanks very much; I'll hit the buy button.
    Glad I could help you.
    Mary
