Small problem with inserting links in posts
akmerlowakmerlow Posts: 1,124
Haven't noticed this behaviour before. But in recent days i notce that when i paste link into post, it somehow adds
to the end of it. So i have to use "switch to source" and manually remove it.
P.S. I'm using MS Edge, if that helps.
  • Are you using the link button in the top two lines of the 'Leave Comment' box to open a window where you can paste the link? If not, you'll almost always get an incorrect link. If you are, I'm stumped.
    Regards,
    Richard
  • Jason GalterioJason Galterio Posts: 2,562
    edited August 2021
    That's a code for "non-breaking space."
    Make sure that you don't have an extra space selected at the end of your copy and paste.
    EDITed to try an add an example, but can't get the nbsp code to appear.
    Post edited by Jason Galterio on
  • akmerlowakmerlow Posts: 1,124
    Regards,
    Richard
    In most cases i just "ctrl+v" link that i get from other browser tab. I only ever use "link button" when i need to turn existing text into a link.
    Maybe it's browser's problem after some update, i don't know. As it didn't happen to me before recently.
  • frank0314frank0314 Posts: 15,116
    It's always been like that. It's jsut part of the coding and doesn't hurt anything. I know whenever I link anything I jsut use the Link function cause it's neater.
