My Daz 4.15 in my new PC crash again and again...Plz help...
Here's the Log File.
And these two sentences appear every time when it crashes, Does anyone have similar problems or solutions? Plz help, and thanks a lot.
WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
3D mouse support library could not be loaded.
2021-08-04 23:54:34.102 NVIDIA Iray GPUs:
2021-08-04 23:54:34.102 GPU: 1 - NVIDIA GeForce RTX 3070 Ti
2021-08-04 23:54:34.102 Memory Size: 7.9 GB
2021-08-04 23:54:34.102 Clock Rate: 1770000 kHz
2021-08-04 23:54:34.102 Multi Processor Count: 48
2021-08-04 23:54:34.102 CUDA Device ID: 0
2021-08-04 23:54:34.102 CUDA Compute Capability: 8.6
2021-08-04 23:54:34.102 PCI Bus ID: 1
2021-08-04 23:54:34.102 PCI Device ID: 0
2021-08-04 23:54:34.102 TCC Mode: disabled
2021-08-04 23:54:34.102 Display: attached
2021-08-04 23:54:34.102 NVIDIA Iray Scheduling Configuration:
2021-08-04 23:54:34.102 CPU Load Limit: 16
2021-08-04 23:54:34.102 CPU Thread Affinity: disabled
2021-08-04 23:54:34.102 GPU Load Limit: 1
2021-08-04 23:54:34.252 Total class factories: 2076
2021-08-04 23:54:34.254 Creating Script Engine...
2021-08-04 23:54:34.263 WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
2021-08-04 23:54:34.263 3D mouse support library could not be loaded.
2021-08-04 23:54:34.264 Creating Main Window...
2021-08-04 23:54:34.265 Creating Viewport Manager...
2021-08-04 23:54:34.291 Successfully created OpenGL viewport for Viewport1.
2021-08-04 23:54:34.341 Successfully created OpenGL viewport for Viewport2.
2021-08-04 23:54:34.374 Successfully created OpenGL viewport for Viewport3.
2021-08-04 23:54:34.407 Successfully created OpenGL viewport for Viewport4.
2021-08-04 23:54:34.447 Creating Action Manager...
2021-08-04 23:54:34.453 Creating Pane Manager...
2021-08-04 23:54:34.594 Successfully created OpenGL viewport for AuxViewportView.
2021-08-04 23:54:38.712 Started in: C:/Daz 3D/Applications/64-bit/DAZ 3D/DAZStudio4
2021-08-04 23:54:38.713 DAZ Studio Started
2021-08-04 23:54:38.713 Creating Pixel Buffer
2021-08-04 23:54:38.728 Pixel buffer - Width: 1024 Height: 1024
2021-08-04 23:54:38.730 Compiling OpenGL Shader...
2021-08-04 23:54:38.763 Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Shader Program successfully linked.
    Those are not causing the crashes and you can get rid of at least one of them by disabling the plug-in.
  • IceCrMnIceCrMn Posts: 2,333
    That's for the spacemouse /CADmouse from
    https://3dconnexion.com/us/
    Starting at around $200USD and hitting around $500USD for the better ones they really aren't what I would call "Consumer grade Hardware".
    If you don't have one, then you can do as PerttiA says and disable the plugin if you want.
    Won't cause a problem if you don't.
    Please attach the entire log file to your next post so it will be easier to help you.
  • Thank you both for helping.
    And here is the log file, thank you guys so much.
    txt
    txt
    log.txt
    511K
    Just looked at the log.
    As far as I can tell it's loading morph deltas then it CTD( crashes to desktop)
    Is that what happens?
    Are you trying to load G8F and the program suddenly closes and you are back to the desktop?
    The lines that caught my eye were "CPU Brand String: 11th Gen Intel(R)" and "Locale: zh_TW"
    Do you have any non US characters in the paths that DS or your content is using?
    About the Gen 11 Intel processor, see this https://www.daz3d.com/forums/discussion/comment/6874141/#Comment_6874141
    Thanks man ,the link you sent works ❤❤❤❤❤
    Yes, mate. It CTD all the time when I loaded G8F and started to adjust anything like pose.
