Anything like an under shirt?
So I'm looking for a shirt to go under a dress something thats skin tight for the most part but also has a high neck. It's okay if it poke through on the body a bit I just need it to be seen through a V-neck.
  • LeanaLeana Posts: 13,611
    When you say "high neck" do you mean like a turtleneck? There are several outfits with one in the store.
    No just high enough that it's visible behind the v-neck.
  • vwranglervwrangler Posts: 5,051
    There's a tank top included with Basic Wear, which comes with the Genesis 8 Starter Essentials, that may do for what you need.
    It isnt high enough, I need something that will cover up most or all of the v-necks cut.
  • felisfelis Posts: 6,573
    If it is just for covering the V in the v-neck, I would go with a geoshell.
    You have to fiddle a bit with a mask for the torsom but I would think it is fairly straight-forward.
    This. yes
  • Lee MoonLee Moon Posts: 940
    It may (certainly) be that I don't know how the Layered Image Editor in DAZ works, but could you use an image of a shirt with the neckline you need and then import that into L.I.E. and position it into the area in the v-neck?
    Again, my knowledge of using the L.I.E. is very sparse.  Perhaps someone more experienced can offer better advice. :)
    Lee
  • nemesis10nemesis10 Posts: 4,032
    I was just going to suggst either L.I>E> or a geoshell...
  • barbultbarbult Posts: 27,618
    You might like the Sexy Skinz line of products in the Daz Store. (Note the Z on the end of Skinz.)
