Does Genesis 8.1 not contain Visemes? My G8 Morph Preset in DazToUnity doesnt show them
Hi guys so i made a preset when i was working with a G8 figure with Visemes to export. Then i tried loading a G8.1 character and seeing if i could export her with the same viseme preset, turns out many of the morphs appeared except the Angry HD, Happy HD, Scared HD, etc those didn't appear and None of the Visemese appeared, then i looked in the character TREE in the left column in Daz tto Unit morph thing and there is no VISEME listning at all. SO Genesis 8.1 has no visemes?
    If you have used DIM/Daz Central/manual installation with your assets, you can get the visemes back if you follow this;
    Making the G8 base expressions (and any expressions that are using them) work on G8.1 requires removing dummy/placeholder expressions that are installed to G8.1 morph folders - These dummy/placeholder expression files have no other function than to prevent the base G8 expressions from loading.
    The dummy/placeholder files are located in;
    ...\Data\DAZ 3D\Genesis 8\Female 8_1\Morphs\Daz 3D\Base Pose Head\ (255 files)
    ...\Data\DAZ 3D\Genesis 8\Female 8_1\Morphs\Daz 3D\Expressions\ (24 files)
    ...\Data\DAZ 3D\Genesis 8\Male 8_1\Morphs\Daz 3D\Base Pose Head\ (255 files)
    ...\Data\DAZ 3D\Genesis 8\Male 8_1\Morphs\Daz 3D\Expressions\ (24 files)
    Please make sure you are removing the files from G8.1 morph folders and not G8 morph folders.
  • nokoteb99nokoteb99 Posts: 943
    Thanks so much!!!!
  • PlatnumkPlatnumk Posts: 682
    The Visemes are there for G8.1,  Make sure use select the Head and not the main figure then goto the parameters - Pose Controls - Head - Visemes
    1074 x 1546 - 346K
  • Hello i  don't have those visemes and others for male 8 & 8.1.
    i don't know from where i get it , help me
