Victoria 4 outfit may fit to Genesis 8 Girl? (The Sentry)
Hey :)
I want to but the outfit The Sentry and I want to ask if its may fit to genesis 8 to
Thanks! :)
  • IceCrMnIceCrMn Posts: 2,334
    I have that outfit.
    I can check for you.
    Is this the character you want to fit it to?
    https://www.daz3d.com/the-girl-8
    I have her also..
  • LeanaLeana Posts: 13,626
    foxyfoxfurries said:
    Hey :)
    Thanks! :)
    It won’t fit directly, but it can be converted with autofit if you have a V4 clone.
    ok,it does autofit to her.
    But the results aren't very usable.
    The boots won't autofit.Shoes are always a problem.
    Any pose other than the default pose will cause lots of distortion in the shoulder armor and the skirt.
    Probably best to use this one with The Girl 4.
    It would be easier to just redo the shaders on G4.
    You can get this outfit to work on a G8 figure, but it will take alot of work to make it look good.
    You'll need to redo the shaders on the outfit aswell.They were made for an ancient version of 3Delight.
    Hey! Thank you , I mean all genesis 8 models like the model Rera , she genesis 8
    There's going to be a ton of things to fix to get it fit on to her, or any G8 character.Pretty close to a complete conversion.
    It works on V4 characters also.
    Since most of the parts that don't bend well will be hidden under the arm pieces(elbows) and inside the shoes(feet), maybe you can look through your catalog of V4 characters and find one that would be similar to Rera?
    It would be alot less work.
    Ahhh thats a shame I really like this outfit , But I will try to search other outfit , thanks :)
