Blender characters into Daz Studio
Is there a way to import rigged characters made in blender into Daz Studio with textures and rigging?
  • margravemargrave Posts: 1,822
    In theory, the FBX importer should do this.
    Good luck getting it to work though.
  • nicsttnicstt Posts: 11,715
    edited July 2021
    I'd use the shrink-wrap modifier to help make a morph for Genesis 8, then adjust rigging to shape and ERC freeze, if needed.
    That way, no irritating rigging to perform.
    Post edited by nicstt on
  • davidtriunedavidtriune Posts: 452
    If it's just genesis chars, I highly recommend shape rigger plus.
  • Okay shape rigger plus? Cool. But what about the import from blender into Daz Studio part? How best to go about that?
    edited July 2021
    It's pretty straightforward if it's a genesis.
    1. you export the character from DAZ as an OBJ on base resolution
    2. you import in blender with "keep vertex order"  checked
    3. make your changes and export from blender as obj and import that into DAZ using the advanced morph loader and find the morph dial on the figure
    4. apply shape rigger plus
    if you already have a character made and you want to convert it to a genesis character, can probably try shrinkwrapping it over your character as nicstt stated but can get messy if your character is very unique and you're probably better off starting over
    Post edited by davidtriune on
  • davidtriune the character is made in blender not Daz. How do I import it from blender to Daz Studio? That's what I'm trying to ask here. It made AND rigged in blender NOT Daz Studio to be clear. And has textures
    If you export as an OBJ, it will have an option to keep the textures--though they won't look the same since shading is very application-specific.
    As for the rigging, as I mentioned, try FBX.
    i dont think there's an easy way. if it's a humanoid i suggest trying what I said and converting it to Genesis8. if it's not, try FBX or import as OBJ and rig it yourself.
  • KainjyKainjy Posts: 913
    I suggest 2 option:
    1. import as FBX (OBJ doesn't support rigs)
    2. import as OBJ in the self pose (and self scale) of a G8. Use Transfer Utility to copy/paste the rigs from a G8 to your model. So clothing/hair/etc.. won't be supported but you will be able to apply G8 poses
    There is also a third option: convert your model to a morph... it's the most complicated solution but you'll be able to use G8 pose and even cloths/hair/etc..
  • I'm tempted to try the third option. Please elaborate. And how would I handle rigging and textures if I do so?
  • Does fbx import support textures?
  • I'm mostly concerned about rigging, poses and keeping the textures if possible. Is fbx import the best way if that's what I want? I'm no good at self rigging. Zero! And forget creating my own textures! It has a rig and textures with it but everything is made in blender as I mentioned before.
    FBX supports texture, the only problem is that you'll have to riassign it to the model when you reimport in DAZ (due diffferent shader).
    When you create an FBX you create the model (fbx) and all the texture in image format.. so it's usually convenient to export fbx in an empty directory.
  • crow122113crow122113 Posts: 9
    edited February 2025
    Basically, Daz and Blender need to have a meeting and get their [stuff] together.
    If you look at PAs in the DAZ Store RawArt, 3DU, and so on: they create new characters as a morph of a Genesis original. 3DU (3D Universe) used to make their own rigs in DAZ Studio but have mostly stopped.
    You can however make your own orginal rigs, example, the DAZ Originals Dog 8, a doberman pinscher, is one such product, but most further dogs, wolves, and other furry animal products since DAZ Dog 8 have been morphs of DAZ Dog 8.
    Post edited by nonesuch00 on
  • crosswindcrosswind Posts: 10,241
    Now there is a Blender To Daz Studio add-on in Blender that can easily get job done as OP requested. Search it on blender market site.
