Genesis 2 Gens UV Map for V4 skins?
AngelAngel Posts: 1,204
edited January 2015 in The Commons
Hi I'm trying to make a nude scene with one of my favorite V4 skins on a Genesis 2 Female.
I don't know where to get a V4 UV map for G2F genitalia.
Post edited by Angel on
  • Richard HaseltineRichard Haseltine Posts: 111,363
    I'm not aware that there is one, just for the main body. You might, if you have them, try the HD morphs that some FWArt characters have instead of using the grafted genitals.
  • nightwolf1982nightwolf1982 Posts: 1,320
    Victoria 4 for Genesis 2 Females includes a UV map for the Genesis 2 Female genitals.
  • AngelAngel Posts: 1,204
    edited January 2015
    If you're talking about this - http://www.daz3d.com/victoria-4-for-genesis-2-female
    No it don't. Trust me I've installed it already. It don't even have UV's for Genesis 2.
    I have that product as well, and I have Victoria 4 UVs for the G2F genitals.
  • riftwitchriftwitch Posts: 1,439
    I have that product too, and the V4 UV is showing for me, both for G2F and the G2F Genitals. What UVs are available on your system for G2F? Maybe something didn't install right.
    edited January 2015
    Not me...
    Image removed for nudity. Please see this thread for info: http://www.daz3d.com/forums/discussion/3279_98/
    Post edited by fixmypcmike on
    And when I click on V4 skins for G2F they don't do squat.
    have you tried re-installing Victoria 4 for Genesis 2 females?
    Is there a Victoria 4 folder in this directory: data\DAZ 3D\Genesis 2\Female\UV Sets\DAZ 3D?
    Is there a Victoria 4 folder in this directory: data\DAZ 3D\Genesis 2\Female Genitalia\UV Sets\DAZ 3D?
    is this thing you may have to save the v4 skin presets as .duf files first?
    Question 1: Yes
    Question 2: Yes
    Question 3: No
  • wizwiz Posts: 1,100
    Next round of questions, did you install V4 for G2F using DIM? If so, go to your DIM downloads folder, find the .zip file for that package, and see if it has the gens, and what the oldest file in the package is. The gens were added to the package a few months ago. You may have to delete both the zip and the manifest to force an install of the latest version if your DIM has been corrupted.
  • scorpioscorpio Posts: 8,533
    V4 tetures won't just apply to G2F you need to convert them to duf files as Misty said.
    Load V4 apply texture save as a Material preset then they will apply to G2F
    It's an install set up. not a zip file.
    edited January 2015
    Other than ensuring you have the latest version installed and that it's installed correctly, I'm not sure what else to add. I can, however, assure you that the Victoria 4 set for G2F also includes a UV map for the geograft as well though.
    Go through the zip file and add it to the directory manually if you're having troubles. As mentioned, it should be in the "UV Sets" folder for the genitals. You can find the zip file in your Daz Install temp directory assuming you haven't set it to automatically clean up installers. Failing that, download it manually and recover the zip file that way.
    787 x 529 - 72K
    537 x 414 - 129K
    Post edited by Herald of Fire on
    What you call an "install setup" is most definitely a .zip file. That's how the DAZ Install Manager works.
    The file name is IM00016559-01_Victoria4forGenesis2Female.zip
    You should also have a file called IM00016559-01_Victoria4forGenesis2Female.dsx
    Verify that the zip file contains a folder called Content\data\DAZ 3D\Genesis 2\Female Genitalia. If you do not have that folder, you have an older version of the package, and you need to force an update the way I said earlier, by deleting both the .zip and the ,dsx file, then running DIM again.
    If you have a file called 16559_Victoria4forGenesis2Female_1.0_trx.exe then we are done here, and you know already know why.
