Genesis Creature bodies and head product not working
The Genesis Creature bodies and head product show up in my product folder but when I click on the picture of them in the folder nothing happens and none of the options appear to beable to apply to any thing on to any figure.
  • Richard HaseltineRichard Haseltine Posts: 111,875
    Are you using the correct figure? Which product is this?
  • jodycourjodycour Posts: 137
    Yes!
    Yes what?
    Those morphs only work with the first Genesis generation figures, not Genesis 2, 3, 8 or 8.1
    Yes I am using the correct figure! Regardless of what figure you have selected when you click on the picture of the product it should bring up a sub category list to show you what is available to use. It doesn't do any thing at all when you click on the product picture! It reacts as if it is not installed but I installed it and uninstalled it and then reinstalled it to be sure and it still does not work!
    Do not understand what you are talking about.
    https://www.daz3d.com/genesis-creature-creator-bodies
    http://docs.daz3d.com/doku.php/public/read_me/index/13033/start
    • This product must be installed to the same Library as the Genesis figure.
    • Morphs are automatically included when a new Genesis figure is loaded and can be found in the Parameters, Shaping, and Posing tabs.
    The file list shows that the only files that are installed, are morphs. ie. You will not find anything in the content library and or smart content because it is not that kind of a product.
    http://docs.daz3d.com/doku.php/public/read_me/index/13033/file_list
    I understand now what's happening it option selections only appears in the parimeters section once you have selected a figure such as genisis 1
  • If anyone is still monitoring this thread, I'd like to add a question regarding a problem with the "Genesis 2 Male Creature Creator HD".
    When installed and having navigated to the morph/shaping menus the icons appear red (see image) and don't really do anything to the figure except wrinkle it slightly.
    I assume the red color means something is wrong as the other morphs installed appear green and work fine.
    I initially thought it was due to my not having installed the 64bit version of DS (which is advised on the product page), but I've now installed it and reinstalled the morphs only to find the same problem.
    Anyone had this issue? Any ideas on how to fix?
    Cheers
    1076 x 796 - 127K
