Deleting scripts menu items
James_HJames_H Posts: 1,114
Is there a way to remove scripts menu items completely. I've just done a reinstall of content, and Daz is now looking to a drive I don't use for scripts. But if I try to add items to the scripts menu via 'add custom action', I am told that the custom action already exists and it points to the old directory. I did try emptying the scripts menu, but that doesn't seem to remove the link to the old location.
The scripts work fine from the content directory, so I assume the issue is that Studio is looking in the wrong place.
  • NorthOf45NorthOf45 Posts: 5,896
    edited July 2021
    The items in the scripts menu are added behind the scenes then the menu is made from those definitions. Go to Customize Daz Studio (F3, or Menu -> Window -> Workspace -> Customize), and look on the left panel. Expand the Custom entry (should be the first one) and you will see all the custom actions that you have added. You can edit them to restore the proper path (strange that it uses an absolute path, not a mapped library path). Not sure if that will restore all the needed info, it might be easier to just delete them from the Actions tab and add them again the usual way. Either way, it's one at a time...
    Post edited by NorthOf45 on
  • James_HJames_H Posts: 1,114
    I had quite a few so the editing would be rather tedious. I'll try to have look at the Actions tab (wrong computer at present).
    All the custom actions are stored in a data file: "%APPDATA%/DAZ 3D/Studio 4/customactions.dsx". You could edit that file directly, but back it up in case you make a mess.
