How Do you Smooth Out Polygons in V4?
nokoteb99nokoteb99 Posts: 944
Although V4 was a step up from V3. For some reason i already see polygon shapes instead of seeing a completely smooth shape.
Is there a way to smooth out the polygons within DS 4.7?
Look at this:
it's in the chest area, but it also happens in legs and so on.
Look at the blockiness polygons
167 x 381 - 59K
  • StratDragonStratDragon Posts: 3,291
    if the figure is supported there are a number of options inside EDIT>FIGURE>GEOMETRY that you could try including, Convert to SUB D, Apply Smoothing Modifier, etc.
    Keep in mind some of these options may significantly increase the memory requirements for your scene and render if they work at all in your scene.
