How to crease edges in Daz Studio?
Here's the deal, i have some meshes modeled from ZBrush and i want to import it into Daz, but the creased edges are not imported.
I know about the shader angle settings, but i would preffer to set my own creases manually, is it possible?
  • JoeQuickJoeQuick Posts: 1,735
    I don't think so?
    Extra edgeloops or bevels can help you get a better edges in studio.  Otherwise normal maps can help crisp things up.
  • j cadej cade Posts: 2,310
    There is actually a way to do it. But you have to select the edges in DS, which is incredibly painful.
    In geometry selection mode you select the edges, right click and then select subdivision weight.
    you can set a value from 0-10
    1996 x 1220 - 259K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,510
    maybe Hexagon bridge?
    it might be an export setting too because I know with Carrara I can keep the smoothing groups on models and they work in DAZ studio
  • Richard HaseltineRichard Haseltine Posts: 111,381
    FBX fro  mood did preserve edge weighting at one time (it is broken in the current modo 10 that I have installed, on the modo end since they don't reimport into modo either). If ZBrush uses traditional edge weighting it may be worth trying other formats for transferring.
