zbrush + Genesis 8 Eyelashes
Howcome Genesis 8 Eyelashes are the only thing, that, when I Goz, the eye lashes come in as a new object instead of updating?
  • Richard HaseltineRichard Haseltine Posts: 111,382
    This is a known issue with the current version of DS - it will be fixed in a forthcoming version. In the emantime you might need to work via OBJ, at least for sending to ZBrush - use the modo preset in the export duialogue and don't forget to hide attachmanets and set the resolution to base.
  • AngelAngel Posts: 1,204
    edited July 2021
     When I export in Zbrush, what setting should I use for Morph Loader Pro or Importing OBJ? Because importing as Daz Studio or Poser, makes the OBJ very very tiny. I have to scale it to about 4000% scale to get it back to normal.
    Post edited by Angel on
    Use the modo preset (or any other Y up, one unit equals one meter preset).
