Timeline is Going Way Too Fast (updated)
Hello. I tried posting earlier about this issue, but I realized I did not give enough detail. My timeline speed is going insanely quick, and  it seems that the lower I set my FPS, the slower it goes, and the higher my FPS is, it goes faster! Normally, it is supposed to be the opposite. This all started happening when i did window>select workspace>city lie (which is the standard), however I do not know how to make this issue resolve. I tried to reset daz but when I redownloaded, the issue was still there. thoughts?
  • Richard HaseltineRichard Haseltine Posts: 111,247
    FPS is Frames per second, so if you set the value high it shows more frames in a second and so goes faster for any given frame count (60 frames at 30FPS takes two seconds, at 60FDPS it takes one second, at 15FPS it takes four seconds). Is that what you are describing or do you mean something else?
  • GordigGordig Posts: 10,786
    I would guess that what the OP is describing is that the timeline doesn't play all frames.
