Some Victoria 4.2 shape++ morphs don't shown in the shaping panel list
Hello, I'm going crazy trying to find morphs, but without success. Can anyone help me out? Thank you.
Buongiorno, sto impazzendo nel tentativo di trovare dei morphs, ma senza successo. Qualcuno può darmi una mano? Grazie.
  • NorthOf45NorthOf45 Posts: 5,915
    If this is your first time using them, V4 must have the morph targets initialized before they can be loaded. (This should have been done automatically when installing with DIM or Central, but it will not work with Connect. Long story). If you use the Power Loader (the default action, unless you changed it at some point), you can generated the needed files by selecting "Generate ExP Files" at the bottom of the Advanced -> Parameters tab of the Power Loader: Import dialog and checking those morph packages that you want to use. (Note; this only needs to be done once, you can uncheck the Generate ExP files box the next time).
    If you have done all that, you need to load them onto V4. They won't load automatically unless you check the box in the Power Loader before loading, or go to the Poser Formats library -> Pose -> DAZ's Victoria 4 -> Morph Injections and apply INJ Morphs++ V4 after loading a V4 character.
    The aren't always at the top level of the hierarchy. For example, all the head morphs are located only on the head, so you must select the head node to see them. Go through the various nodes of the skeleton and you will get a different set of morphs for each.
  • Richard HaseltineRichard Haseltine Posts: 111,776
    In order for properties to appear in the Shaping pane they have to have their type set to Modifier/Shape in the property settings dialogue (click the gear icon on the slider in the Parameters pane).
  • Perfect, thanks to NorthOf45 and Richard Haseltime for help. yes laugh
