Where Are The Shaders?
GeneralDeeGeneralDee Posts: 132
I have a a skin on a character that I would like to use on a added body part. The texture matches nicely in the viewport but a render reveals one part being lighter than the other. I discovered that the parts are using different shaders. One AoA and the other omHumanShader. I cannot find the shaders in the content lists anywhere. Where do we find the shaders (AoA, omHumanShader, Etc.) to match surfaces? Or what is the proper way to deal with this issue?
    On the Surfaces pane, the different shaders will show up under Presets; or you can also get to them in Content Library > DAZ Studio Formats > My DAZ 3D Library > Shader Presets
  • GeneralDeeGeneralDee Posts: 132
    edited January 2015
    EDIT: I looked really good and found them in the content library :red:
    Thank You
    Post edited by GeneralDee on
    Subsurface Base Shader is the AoA shader. Did you install "DAZ Studio Default Lights and Shaders"?
    See my edit above. Was typing at the same time of your reply.
