Agna V4 character inject gives error
dbdigital2dbdigital2 Posts: 270
Now I have used the character before but now when I inject the character morph into onto V4 I get
Warning: Could not find file
:Runtime:libraries:!DAZ:Victoria 4:Deltas:The Girl 4:InjDeltas.SCLG4TheGirlScaleOn.pz2 on line 20 in C:/Users/Public/Documents/My DAZ 3D Library/runtime/libraries/Pose/AGNA/AGNA_INJ.pz2
I haven't been messing around inside my runtime or uninstalling anything so this is a bit of mystery. It also seems to inject fine when I skip the error, at least the character doesn't look that different (if there is a change it is not a large one)
Also I now see a ton of errors on another product when I load it, and while it seems to load and look ok, I don't remember this error before. But it is possible I just didn't notice it as it doesn't stop and say "warning can't find..."
Warning: Invalid name "V4LHipGluteFwd-Bkwd" for deformer prop was specified on line 1677 in C:/Program Files (x86)/Curious Labs/Poser 5/Downloads/runtime/libraries/character/V4 Bunnygirl/V4 Bunny Suits.cr2
Warning: Invalid name "V4RHipGluteFwd-Bkwd" for deformer prop was specified on line 1695 in C:/Program Files (x86)/Curious Labs/Poser 5/Downloads/runtime/libraries/character/V4 Bunnygirl/V4 Bunny Suits.cr2
Warning: Invalid name "V4AbdomenBackFwd" for deformer prop was specified on line 108616 in C:/Program Files (x86)/Curious Labs/Poser 5/Downloads/runtime/libraries/character/V4 Bunnygirl/V4 Bunny Suits.cr2
This product though is from another market/site. Any ideas? The suit errors I am guessing I just didn't notice them, but seems odd that I would have when I checked it after installing. And yes I have several runtime paths, and they are properly specified in Studio.
  • fixmypcmikefixmypcmike Posts: 19,739
    It looks like you have V4 installed under Program Files (x86) -- Windows 7/8/Vista protect that folder by moving files to a virtual store, so the files aren't really where the OS is saying they are. The best solution would be to uninstall V4 and her morphs from that location and install them elsewhere, such as in the Users folders.
  • dbdigital2dbdigital2 Posts: 270
    edited January 2015
    Nope they are installed with DIM in the default location C:/Users/Public/Documents/My DAZ 3D Library/runtime as I posted, not in the programs area protected store. Now the second item suit product is, but I don't have any trouble with any other items installed in there. But I might try creating a new runtime directory and just installing the suit and see if the error keeps popping up.
    But again this doesn't explain the program with the character. The character, V4 and ++ morphs were all installed with DIM. Actually everything I get from Daz is installed via DIM to the default location with the exception of Bryce which usually needs files moved manually (presets) after installing. But that is the only one.
    Post edited by dbdigital2 on
    Check that you don't have more than one Runtime with a "Runtime:Libraries:!DAZ:Victoria 4" folder, and that The Girl 4 is installed to that location, then double-click DzCreateExPFiles-V4.bat in Runtime:Libraries:!DAZ -- a black window will open up, run through all the morphs, then close. You are injecting the character into a fresh V4 loaded from the cr2, or into a saved V4 in a DS scene?
    You may need to do a complete uninstall of Poser then re-install Poser and its default Runtime outside of Program Files folders. I believe with Poser 6 it could execute the ExP scripts in DAZ's generation 4 figures if they were not inside Poser main Runtime, Poser 5 may be the same way (further Poser 6 is the earliest version DAZ recommended for using gen 4 figures if I recall correctly).
    Poser 6 required the Morph files to be installed to the same runtime as the base figures. It was only once Smith Micro purchased Poser that things changed.
    Well in this case I moved/copied the suit to a new/different runtime folder, loaded on a fresh copy of V4 and same issue. So the "Warning: Invalid name “V4LHipGluteFwd-Bkwd” for deformer prop" is not due to that. Might be due to being a poser product rather than Studio. It works, and I am not finding any problems with it other than the warning.
    The Agna V4 character I am still having the issue. While the character seems to look ok after the injections, the error makes me wonder if I am missing something. Also another odd aspect, I never had The Girl 4 at all (and still don't). But the character doesn't say it is a requirement.http://www.daz3d.com/agna-for-v4-by-third-degree now there is a The Girl 4 version of it, but I don't own that one. Perhaps this is a glitch I just didn't notice when I originally installed/tested that is in the product itself. Still seems like I would have noticed a STOP CAN"T FIND box popping up lol.
    And yes I am doing the injections on a fresh copy of V4 with ++ morphs added. I haven't tried DzCreateExPFiles-V4.bat yet, but I will. Although at this point I suspect it is just a glitch in the product.
    edited January 2015
    Ok I ran the DzCreateExPFiles-V4.bat in Runtime:Libraries:!DAZ but that didn't fix the issue. Strange. Does anyone else have http://www.daz3d.com/agna-for-v4-by-third-degree ? I would like to know if anyone else runs into this error. Of course if one has The Girl 4, they wouldn't get the error anyway by the looks.
    (sorry for the slow response here, I had to fix the database first then a few other projects needed my attention)
