Missing file PBRSkin.dsf - Answered & Solved
richardandtracy
I wonder if someone could help me. I appear to be missing the following file:
Data/DAZ 3d/built-in content/daz iRay pbrskin/pbrskin.dsf
I am trying to use G8.1F for the first time, VYK Ritchie. Looking at it, it looks like it's a DAZ file, so can anyone give me an idea which DAZ download it is in? I'm using 4.15, have downloaded the revised G8 starter essentials, but this file seems to have eluded me in my manual downloads.
Thanks in advance, Richard
Post edited by richardandtracy on
You'll need the new "Default Resources" aswell.
Delete the old download package from DIM first to force it to download the new one.
That's the one I have.
Not sure how you'd go about doing a manual uninstall of the old one first.
Hope it goes well with just a manual overwrite of the old files.
Should be able to find the new shader in
/Shader Presets/Iray/Daz PBRSkin/Daz Iray PBRSkin.duf
I came here with the same problem. Your advice helped. Thank you!!
Hi, I'm new to DAZ Studio. I have same issue. Where can I find DefaultResourcesforDAZStudio415 on DAZ website please? Not in any of my orders. Thanks!!
Thanks!! Downloaded IM00013176-42_DefaultResourcesforDAZStudio415.zip but not sure what directory path to download too. Moving over from Poser
I've also Uninstalled/Installed Default Resources via DIM but not seeing it. Thanks!!
If you in DIM click on installed and search for it. Then right click on it and there is an option for showing installed flies.
Did you let DIM go online to check for updates?
I found the Daz Iray PBRSkin not in the SMART Content Tab but in the Content Library Tab. Not sure if it was loaded properly. Still too new for Studio. Thanks!!
it's workig for me
