hairy issue
VIArtsVIArts Posts: 1,539
I'm using th V5 Elite Ponytail and aOA's advanced lights. I want the hair tox render dark brown, but even if I set the diffuse to a darker color, ii looks blonde vor too light. I've messed with a few settings, but can't seem to figure it out. Any ideas?
  • Cris PalominoCris Palomino Posts: 13,050
    Can you show a pic of your hair as it's rendered? Show a pic of the settings where you can see ambient and if there's any subsurface scattering on it? Are you using Uberhair or anything to help it render quicker?
  • Rashad CarterRashad Carter Posts: 1,834
    I don't have any experience with this but I think I've read several places that there is a "flag" of some sort that a user needs to enable to use hair and AOA lights at the same time with reliable results. Hopefully someone knowledgeable will chime in soon.
  • VIArtsVIArts Posts: 1,539
    Um, that's weird. It seems to be the Opacity Active: On that's making it lighter. I Ctrurn it off, it renders dark. Everything else is default.
    It does load with UberSurface.
    here's a snip.
    1920 x 1080 - 515K
