Since the changes in Studio 4.7
Daniel BarnettDaniel Barnett Posts: 389
I hope this makes sense - Since the changes in Studio 4.7 I can't find the transition tool (red green blue) in the preview pane that helps to move an object around in the scene.
I'm using a copy of city limits as my theme.
thanks
dbb
  • Richard HaseltineRichard Haseltine Posts: 111,718
    You probably need to change your selection in the Tools menu. The arrows are on the Translate and Universal tools (and Active Pose).
  • Daniel BarnettDaniel Barnett Posts: 389
    Did they do away with the cube tool that was always in the corner I think there was a circle with translate functions also?
    thank you
    dbb
    Ah, that sounds as if you have docked (or the layout has docked) your view controls. If so you will have a horizontal bar across the top of the viewport, with the view seelction and draw style buttons on the left and the camera controls on the right. Next to the draw style sphere is the option menu button - right-pointing arrow and lines. Click that and select Cuibe View Controls.
