Looking for another way to transfer character morphs to clothes
sjjesso_78ca0e6d0csjjesso_78ca0e6d0c Posts: 79
I have a program called Morphing Clothes 1.2 that did a really good job of adding Character Morphs to M4 V4 and K4 clothes. That is until I installed the latest version of DAZ Studio. Now the added morphs not only don't work, they don't show in the Parameters section (only the morphs that the clothing model came with).
I need an alternative as these character morphs will not work with Genesis or Genesis 2. I have tried Generation X but not all of the Character morphs will transfer to genesis (applied morphs won't work with the Eyes and inner mouth). And before someone suggests Transfer utility that only works with Genesis figures.
Any help is appreciated.
    After using transfer utility, you can save this Genesis outfit and then autofit to Gen2F/Gen2M, it is always a workaround.
  • sjjesso_78ca0e6d0csjjesso_78ca0e6d0c Posts: 79
    Yeah but I'm trying to add Gen 3 morphs to Gen 3 clothing. Transfer utility will not work with Gen 3 figures like Micheal 4 which has always been an inconvenience.
  • fixmypcmikefixmypcmike Posts: 19,710
    What figure are you intending to use the clothing on? Morphing clothes should be fine if you are planning to use them on the figure they were made for.
    Kids 4 with Kids 4 Clothes, Victoria 4 with Victoria 4 clothes, Micheal 4 with Michael 4 clothes. Morphing clothes worked just fine until I installed DAZ 4.7. Now it doesn't work. I'm thinking I'm going to have to go back to an earlier version whether I want to or not.
  • Mistress SaekoMistress Saeko Posts: 51
    edited January 2015
    Here's what I do since I don't have Morphing Clothes:
    * Load the clothing item
    * Fit to character
    * Add the morphs you want to the character
    * set the morphs to 1.0 or 100%
    * Edit>Figure>Transfer Active Morphs
    * Reset morphs
    * Export clothing to CR2 or whatever
    Post edited by Mistress Saeko on
    * Fit to character
    * Reset morphs
    Transfer Utility only works with Genesis. It does not, and never has as far as I know, work with any other model like Michael 4, Victoria 4, or Kids 4.
    edited January 2015
    There's another option called "Transfer Active Morphs". It does not refer to the Transfer Utility.
    Screenshot
    Tried that. No good. Thanks anyways though.:)
