Just bought GRAPHMATE on daz 4.7... and I can't find it!
gidduegiddue Posts: 7
Hi to everyone!
As described in the title, I've just bought the GraphMate plugin for animation: I've tried to install it both with daz manager and with manual installation (I'm running the 64bit version of Daz 4.7) but I can't find the graphmate tab anywhere! I've already searched in the list of the tabs, but it does not appear... any suggestion?
Thanks and regards
giovanni
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Have you entered the serial number? if not, in the Install Manager right-click on the KeyMat entry, select Show Serial Number, and click the Copy button, then go to DAZ Studio, help>About Installed plug-ins, find the entry for Keymate and paste the serial number into the box. Click Accept and restart DAZ Studio.
  • gidduegiddue Posts: 7
    Hi, first of all thank you very much for the reply!
    I've checked the installed plugin list (under "help/ about installed plugins) but I can't even find GraphMate here! It's like it has not been installed at all...
    If you installed DS with DIM, is the KeyMate plug-in shwoing as installed there too? If not try reinstalling - it's possible the manual installer, if that's what you last used, went to a different location.
    Hi, I've installed the keyMate and it shows as installed and working.
    I had the same suspicious, that the graphMate has been delivered to the wrong position by the installer... I'll try to launch again the installer of the Key Mate and see what is the default directory, then I'll check that the GraphMate is delivered in the same one... I'll let you know, thank s for the reply!
    giovanni
