using grab helper model losses texture
Ive  had trouble using this new morph tool .. When I aply it it works but I loose the models texture except on the gloves ..  Im not sure why it is doing this... I cannot reaply the textue model remains marble white..
  • Richard HaseltineRichard Haseltine Posts: 111,890
    Which version of Daz Studio? That sounds as if the shell, which should be invisible, is remaining visible.
  • prinzeugenprinzeugen Posts: 40
     Version 4.15 ... Everything looks normal until I load grab helper...
    Yes, it uses a Geometry  Shell to work its magic, as I understand the process.
     Ah !  Ok got it ...  If using other shells you need to hit shell fix   !  Duh !!  Thanks for the help..
