How do you reset a figure's axis of rotation?
Hi, A figure should rotate/translate based on the position of the figure relative to the ground directly underneath it, but this can get fouled up and right now I've got a figure rotating relative to a spot well off to the figure's right.
How do you reset this?
Thanks
  • margravemargrave Posts: 1,822
    Use the Joint Editor tool, and make sure you have the Tool Options pane open to adjust the values.
  • TBorNotTBorNot Posts: 380
    Select the figure's hip and make sure the various Translate and Rotate values are zero.  Quite a few pose libraries change these values.
  • heisdaveheisdave Posts: 130
    Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,743
    Daz store poses shouldn't move the hip, other than to keep the feet (or whatever the cotnact point is) on the ground and to place figures in multi-figure poses correctly. If a pose set is moving the hip for other reasons please report it.
  • melaniemelanie Posts: 807
    I just had this happen and I think I figured it out. At least with my default camera I did. It's not the character that's off center. It's the camera focal distance. Select the camera and then click on Camera, then Focal Distance. I reset that by holding down Alt and clicking the peramater slider to set it to the default 450.00 and now my character doesn't swing around in a wide arc. I hope this is what you were trying to achieve.
