Mirroring a joint corrective morph
TheCedizTheCediz Posts: 172
Hi, I've been struggling for couple hours, now I am here again in search of answers.
All went well for the JCM I created for the left side thigh; I want the JCM to activate when the thigh rotation side-side is active. I create the morph in Zbrush for the left side, make the morph a type modifier/pose, then open property hierarchy to find 1st stage controller of new morph and drag and drop the Left tigh side-side rotation pose I need to correct and it works all well. Up to this I think I'm doing everything okay
The right side is now the problem and it has to do with the attributed sign of the right side it seems (Left bends in (+) and right bends in (-)). So, I grab the morph I made for left side­ > morph loader pro > hit the morph mirroring option to "swap x axis" (this I'm not sure it's the right option). The morph comes out okay for the right side. In property hierarchy, I do the same as the left side but for the right tigh and now, the resulting JCM is kinda inverted. I want the morph to go from 0 > 100 when the joint (R side-side bend) goes open 0 > -50. As of now, my morph is applied (+) when the bend closes -50 > 0.
Is the problem with the right side in property hierarchy or when I mirror the morph in morph loader pro? I think I would need my morph to invert the sign, so instead of gradually applying from 0 > 100, it would applies from 0 > -100, as all Right pose transform do. How can I do that?
Any alternative?
Big thanks
Post edited by TheCediz on
    edited September 2024
    Yes that is a 'fun' situation. Needs 3 morphs ;-) Here's my little tutorial on how to:
    all sharecg links are retired ;-)
    Tutorials now at DeviantArt and/or Renderosity [PetuniaPetals].
    https://www.deviantart.com/catherine3678ab/gallery/74400506/tutorials
    [edited to update]
    Post edited by Catherine3678ab on
  • TheCedizTheCediz Posts: 172
    Aren't you exactly what I needed; not the first time you save my ass Catherine! I'll make sure to follow and check out everything you have on ShareCG.
    Thank you!
    Thank you!
    You're welcome :-)
    I do not know all the deep dark secrets of making joint corrections etc. but enough to tippy toe through the waters now and then ;-)
    edited July 2021
    For anyone having the same problem if it is a negative bend:
    you drop the controller morph/pose in Propperty hierarchy > your JCM/MCM > controller > 1st stage. Then under the morph in 1st stage  > Attribute > Scalar ; set the number to negative.
  • butre3004butre3004 Posts: 0
    edited April 2024
    https://sharecg.com/v/97315/view/3/PDF-Tutorial/Making-pJCMs-for-Clothing
    Hi! the link doesnt work!
      Slight necro just to say thanks, was tearing my hair out when trying to make corrective morphs for some clothing I made in marvelous. All the tutorials for JCM's just show how to do it on the positive axis and then move on lol.
  • lilweeplilweep Posts: 2,864
    I just use keyed. seems so much easier to comprehend than any of the other options...
    occasionally use subtract
    ... sharecg.com/v/97315/view/3/PDF-Tutorial/Making-pJCMs-for-Clothing
    It did a few years ago ;-)
    Some of my tutorials are now over here: https://www.deviantart.com/catherine3678ab/gallery/74400506/tutorials
    The rest of what I still have released are over at Renderosity where I'm PetuniaPetals.
