Cannot select bones of rigged item
UncannyValetUncannyValet Posts: 277
edited July 2021 in Daz Studio Discussion
Usually, with a rigged wardrobe item figure, you are able to select the facegroups associated with a bone and then you can pose that part of the figure.
But I have created a figure asset, see pictures attached, which when selected with any of the posing tools (e.g., translate, rotate, active pose tool) it selects only the whole asset rather than face groups/bones
Is there some setting that can rectify this?
I realise I could easily work around this by posing the figure in other ways, but  would rather fix it.
Post edited by UncannyValet on
  • Richard HaseltineRichard Haseltine Posts: 111,984
    You need those polygons assigned to a group, then in the Tool Settings pane with the Joint Editor active and the bone selected you make that group the bone's Selection Group (top-right of the pane).
  • UncannyValetUncannyValet Posts: 277
    edited May 2023
    Ah okay, thanks - i was looking in that tab but couldnt figure out how to change the face groups.   (I just had to select the bone first)
