Genesis 2 Morphs and Poser?
sometaureansmucksometaureansmuck Posts: 2
Hi,
I have Genesis 2 morphs, but I can't get them to work in Poser Pro 2014.
I reinstalled Genesis 2 into my runtime directory using the Poser CF, I think. I know there was a separate thing for G2.
The bases work fine with the DSON importer, but when they load the morphs are not on them. Yes, I have the body selected.
The files are in Runtime/Data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D and there is an Evolution Body and Evolution Head folder.
Additionally, I cannot find any pose in the library to apply the morphs like done with V4.
I am sorry for my english, please help me.
  • FistyFisty Posts: 3,416
    the "data" folder needs to be next to the "runtime" folder, not inside it.
    936 x 1040 - 270K
  • LeanaLeana Posts: 13,502
    Hello.
    There are no injection poses for Genesis and Genesis 2, all morph channels are ready to use when you load the figure. In DS the morph is loaded in memory only when you first set it to a non-zero value, it's probably the same with the DSON importer.
    As for why the morphs are not working, it's probably because the data folder is not in the right place. When you install DSON files to your Poser content directory the "normal" place for the data folder (and other DS-specific folders like People) would be in the folder that contains the Runtime folder, not inside the Runtime.
    Check where your G2F DSON files (not Poser CF) are installed, the morph data files should be under the same top-level data folder as the ones for the base.
  • sometaureansmucksometaureansmuck Posts: 2
    Hi,
    thank you for the help, friends. It works.
