How do you Have an object (Lamp/flashlight etc) Emit light in DAZ ?
nokoteb99nokoteb99 Posts: 943
edited December 2014 in Daz Studio Discussion
Not using Reality or anything. Just normal 3DDelight rendering. And of course the viewer should see the glow coming out of the object.
I've never seen it done.
Post edited by nokoteb99 on
  • Richard HaseltineRichard Haseltine Posts: 111,371
    If you want a surface to emit light apply the uber Area Light shader to it, from the Light Presets folder; use the Surface pane to adjust its settings. You will need another, real, light in the scene (even if the intensity is set to 0) to block the default headlamp/
  • SzarkSzark Posts: 10,634
    Richard the Area Light base will provide a Headlamp blocker.
    nokoteb Tutorial Uber Area Lighting: The Basics
    also are you wanting a visible beam of light as that requires either a Volume camera or an Uber Volume Cone parented to a spot light , the latter comes with Daz Studio the former is a purchasable product from the DAZ3D store
  • pwiecekpwiecek Posts: 1,598
    If you want a visible beam, look for 'Volumetric Lighting'.
