How to light a flashlight?
bern131088bern131088 Posts: 7
edited December 2014 in New Users
Hello! Do you know how to light a flashlight like the picture? What type of light do you use?
Thanks!
492 x 443 - 241K
Post edited by bern131088 on
  • Richard HaseltineRichard Haseltine Posts: 111,972
    Are you wanting the light cast by the torch, the glow at the end of the torch or the lens flares (or some combination of the three)?
  • bern131088bern131088 Posts: 7
    I mean, all of them, what do you use to achieve that?
  • les-2605719les-2605719 Posts: 16
    Hi,
    I have never tried to render it in DAZ, but I done it with post-work in GIMP. It has a tool called lens flare, that has a nice effect.
    Have you tried a spotlight pointed directly at the lenses of your camera in your scene. I would try that in your scene first or a transparent.plane with a few orbs painted on it as a texture., then positioned in between the camera and light source.
    Post edited by les-2605719 on
    For the visible light source: up the ambient to 100%, white and perhaps take limits off the Diffuse strength and increase that (click the gear icon on the slider and go to Parameter Ssettings).
    Parenting a spot or point light to the torch will make it cast light, as will applying the uberArea light shader to the torch lens.
    For a visible beam, apply a cone primitive and turn its opacity right down low so it just catches a bit of light. You might also adjust the ambient on that.
    Lens flare is probably best done in a n image editor, but you could apply a lens flare effect (with a transparency map to match) to a plane primitive.
