Charachter Translation Locked. How to resolve?
Hi to all..i don't know why but maybe i activated an option that don't allow me to move the body part of mi charachters. I can rotate, move side by side but i can't translate.
I can't do nothing anymore. I tried to unistall and reinstall, i tried all the option in the menu but nothing works.
I also tell you that the parameters x tranlation ecc ecc are hidden and if i write a value or i try to move the bar nothing happen.
i show you some pictures of the problem.
  • GordigGordig Posts: 10,799
    edited July 2021
    A couple things are going on here. First off, you don't generally want to translate bones, because they're not designed to work that way and you'll get some pretty ugly results; that's why the translate controls are locked and hidden. If you want to translate, all you have to do is click on the lock icon to unlock the parameter. You're also on the "bend" bone, which explains why the twist is locked and hidden. There's also some pinning in place, represented by the purple pin on her collarbone, although you might have pinned the bone intentionally. You can either click on that purple pin to unpin that bone, or click on the larger pin at the top-left of the viewport to unpin all.
    edit: I just tried it, and the translate parameters are also limited to a min and max of 0, so you'd have to either change or disable limits in order for those to have any effect. To illustrate, here's what a bone translation looks like.
    351 x 292 - 44K
    375 x 287 - 48K
    Post edited by Gordig on
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Please put the Viewport in a non-textured mode (or remove the textures) if you are taking images of nude figures.
  • mbtimembtime Posts: 0
    Richard Haseltine ha detto:
    Per favore, metti il ​​Viewport in una modalità non strutturata (o rimuovi le texture) se stai scattando immagini di figure nude.
    Sorry, it was the genesis basic. i will change image
