Smart Prop and Parenting
tomsfo1tomsfo1 Posts: 87
Grrrr! I spent a lot of time posing a hand to properly hold an apple. My objective is to make this a Smart Prop so the next time I want to call up the figure and prop it will load to the hand and follow the hand if I change the pose.
I understand to make a Smart Prop I need to parent it to the hand. But when I do so, it moves the apple from the exact placement I had when conforming the hand to hold it, to the palm of the hand.
How can I save the apple as a Smart Prop to the proper placement instead of the palm?
I also saved the figure's pose with the modified hand pose as a Preset > Pose, but when I attempt to load it I get an "Error opening file" message. I checked the Log file but it only says: "*** Scene Cleared ***, Error reading file, see log for more details."
Any help would be appreciated.
Thanks for your response.
Tom
  • Richard HaseltineRichard Haseltine Posts: 111,332
    Make sure parent in Place is on when you change the apple's parent - it's a check box if you are using the Change parent dialogue, or a checkable menu item in the Scene pane option menu (lined button in the top corner, or right-click the tab) if you are dragging and dropping in the Scene pane.
  • tomsfo1tomsfo1 Posts: 87
    Thanks Richard,
    Sometimes it is the most obvious or littlest things we miss.
    Your response is appreciated.
    Tom
