Please help me open this travel bag
https://www.daz3d.com/travel-baggage
How can i open it in daz studio?
1611 x 894 - 2M
  • FenixPhoenixFenixPhoenix Posts: 3,247
    According to the information, the bags should have bones that you can move to open them.
  • NorthOf45NorthOf45 Posts: 5,912
    Select the top level item in the Scene tab, and look in the Parameters tab for Actor controls. Some controls activate more than one part that would be hard to coordinate individually, like "Lay Down & Open". Others can use the individual bones.
  • HaruchaiHaruchai Posts: 2,040
    edited July 2021
    Here is a link to the file list on DAZ's documentation page. At the top are listed all the Morphs. Try putting some of these names in the search space at the top of the parameters pane with the object selected. If you can't find any controller morphs in the actual parameters list that is. Just try 'open' for starters.
    http://docs.daz3d.com/doku.php/public/read_me/index/34497/file_list
    Post edited by Haruchai on
  • PlantPlant Posts: 127
    If you select the bag you should see the dials as in attached pic
    559 x 686 - 73K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,645
    I wishlisted this thanks to this thread yes
  • EllessarrEllessarr Posts: 1,395
    hmm you got me interested, if not asking too much you can post the poly count of each bag? if they are not "high poly" then i can use then for my project
    in case you don't know how to do it here a post about how to do
    https://www.daz3d.com/forums/discussion/450236/some-help-with-outfits-poly-count
    you can follow this post
    https://www.daz3d.com/forums/discussion/comment/6212066/#Comment_6212066
    but instead of show all info i just need the "total vertices", the triangle and faces are not needed then you just need it something like that
    bag name 1
    Total vertices:
    1000/100
    bag name 2
    Total Vertices:
    1000/100
    and going, just need the vertices number if the bags numbers are not above let's say 5k to max of 10k( which for this type of product already a lot) then maybe they can be used, in case they go really high like more than 10k going to let's say 100k+ then they are really bad.
    Got me interested in it also thanks to this thread.
  • chanurchanur Posts: 64
    As seen from my Scene Info:
    Classic Bag
    Total vertices:
    31.563/31.563
    Hardshell Suitcase
    Total vertices:
    26.909/26.909
    Softshell Suitcase
    Total vertices:
    44.026/44.026
    Sport Bag
    Total vertices:
    22.839/22.839
    Trolley
    Total vertices:
    17.713/17.713
  • ArtiniArtini Posts: 10,920
    edited July 2021
    These bags are very well made. Esha is a talented artist.
    1920 x 1200 - 403K
    Post edited by Artini on
