Please Review - WIP Science Fiction Corridor
I have struggled to model a science fiction scene that I was really happy with.  I have also struggled to come up with a color scheme that I liked as well.
This is a work in progress of what will be a corridor. I am not trying for a dystopian look, rather a shipboard environment that is well maintained.  The wall is 15 feet tall and 15 feet wide.  Constructive reviews are welcome and appreciated. Thanks.
800 x 800 - 160K
  • TorquinoxTorquinox Posts: 4,856
    It's an attractive panel. The colors seem suitably somber. There are a lot of junction boxes there. Not sure what they do, and probably not every panel in the corridor would need those. A whole environment is tough. If you're motivated to do it, I'd say keep going, make more panels, a whole corridor, whatever you fancy. Then see how it looks when you put it together.
    Thank you for the feedback.  The junction boxes were initially intended to be equipment to breakup the blank space.  As time and modelling went on I decided that they would be power supplies, controllers and consolidation points for computer controlled devices.  When I got tired of making junction boxes I duplicated the ones on the left side and decided the equipment need redundancy in case of failure.  :) You are correct, they would not be needed in every panel.  The way I have modelled this I can adapt the panels to different uses.  I can put a door in one panel, a viewport or window in another, etc.
    yes Sounds pretty cool! :)
