Why do i get this message everytime i start up DS 4.7 ( In mac)?
nokoteb99nokoteb99 Posts: 943
I get this annoying thing and i always have to push DENY.
494 x 178 - 69K
  • nokoteb99nokoteb99 Posts: 943
    edited December 2014
    if i already have it block in the firewall, then why does it keep
    giving me that mesage. Look, i looked in the mac Security preferences and it's
    blocked. so why then do i get that message?
    519 x 165 - 41K
    Post edited by nokoteb99 on
  • PlatnumkPlatnumk Posts: 682
    You need to unblock it, Daz Studio requires network/internet access to work.
    Well my DAZ STudio works fine even if i Push DENY. But i guess i have to Unblock it? Why is that? what if i did't have internet?
    I'll try unblocking it.
  • TotteTotte Posts: 15,188
    postgres is the Content Manager Database used by DAZ Studio, and if DAZ Studio cannot access it several things will not work properly. Smart Content will not work, database search will not work, and Genesis/Genesis 2 auto-fit-to when adding clothes to a figure won't work properly.
    You should allow postgres to accept incoming connections from localhost (your own machine)
    Post edited by Totte on
    That security message is a bit misleading, all that's happening is two programs talking to each other — the database manager program needs network access internal to your computer to access the content database and send what it finds to the DAZ|Studio program.
    And Auto-Fit works just fine without it, what will happen is some items will not auto Fit-To so needs to done either by right clicking on them in the viewport and setting in the pop-ups or selecting in Scene tab and setting from Parameters tab (General/Misc).
    Not Auto-Fit, but auto "Fit to...". When you have a Genesis-figure selected and add a piece of clothing and the CMS is not there, you will have to do "Fit to..." to make it conform.
    Ok decided to Allow access to postgress in the Macos Security settings firewall.....and yet i still get the message upon starting up DAZ Studio. What's going on?
    Is postgres running? Did you allow DS to start it?
    yeah i always alow it. Everytime DS starts it pops out the message and i push Allow.
    What ports do you allow?
    In DS under Preferences, CMS Settings you see the Port number DS uses to connect to postgres, it is not using the standard postgres 5432 port number to avoid collisions if there are other postgres installations on the machine. 17237 it says on my OS X Machine which I guess is the default DS postgres port
    in my DS CMS settings it says port 1024. should i change it? And to what?
    What does postgres listen on? DS can have been tricked when it was blocked...
    I don't know. I dont know too much about these internet computer things. How do i know what it listens on?
    if you look in your DS log (Help->Troubleshooting->View Log File...) and look for the line "Creating Asset Manager..."
    What does it say after that?
    I'm still having the message even though in Macos SEcurity/Firewall preferences i allow incoming connections to both DAZ and Postgress.
    regarding your question , after Creating asset manager... i have this
    Connected to CMS: PostgreSQL 9.3.4 on x86_64-apple-darwin, compiled by i686-apple-darwin11-llvm-gcc-4.2 (GCC) 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.9.00), 64-bit
    *** Scene Cleared ***
    Loading plug-ins:
    libaniMate2.dylib
    libdazscriptide.dylib
    libdzalignace.dylib
    libdzassetiofilters.dylib
    libdzautofit.dylib
    libdzautoriggerbasic.dylib
    libdzautoshaderbakeractions.dylib
    libdzbrycebridge.dylib
    libdzbvh.dylib
    libdzcolladax.dylib
    libdzcomponents.dylib
    libdzcontentdbeditor.dylib
    libdzcontentlibrarypane.dylib
    libdzcr2exporter.dylib
    libdzcustomizedlg.dylib
    libdzdelightrenderer.dylib
    libdzdformeditor.dylib
    libdzeasyloader.dylib
    libdzexpexporter.dylib
    libdzfbxexporter.dylib
    libdzfbximporter.dylib
    libdzfiguresetup.dylib
    libdzhexagonbridge.dylib
    libdzimageio.dylib
    libdzjointeditor.dylib
    libdzlayerededitor.dylib
    libdzlayerfilter.dylib
    libdzmacvideo.dylib
    libdzmanualshaderbaker.dylib
    libdzmaptransfer.dylib
    libdzmorphfollower.dylib
    libdzmorphloader.dylib
    libdzmorphloaderpro.dylib
    libdzobjexporter.dylib
    libdzoptitexclothbasic.dylib
    libdzpolygongroupeditortool.dylib
    libdzprimitives.dylib
    libdzpropertyhierarchyeditor.dylib
    libdzpuppeteer.dylib
    libdzpz3importer.dylib
    libdzrenderedit.dylib
    libdzrenderlibrary.dylib
    libdzrslshadercompiler.dylib
    libdzsavefilters.dylib
    libdzscriptedrenderer.dylib
    libdzscriptedsteps.dylib
    libdzshaderbaker.dylib
    libdzshaderbuilder.dylib
    libdzshadereditor.dylib
    libdzshadermixerbase.dylib
    libdzshadermixergui.dylib
    libdzsmartcontentpane.dylib
    libdzspotrendertool.dylib
    libdztextureatlas.dylib
    libdztransferutility.dylib
    libdzu3dexporter.dylib
    libdzweightmapbrush.dylib
    SDK_SceneInfoPane.dylib
    libdzdrawstyles.dylib
    libdzpowerpose.dylib
    Reality_DS64.dylib
    Error writing author data!
    Which mean DS can connect, but id DIM wasn't allowed to connect when content was installed, metadata will not be in the Database.
    Have you tried to reimport metadata (now when the connection works) (I just don't have time to read through the whole thread again to look)
