Hard drive 100% when Render
NamelessxPeasant
I have three hard drive, a 250G SSD, 1TB HDD ,1TB SSD, I first install my Daz inside HDD, and then I realize somehow when I render, the HDD drive always reach 100% and cause computer lag, so I move all Daz program and Content library to my 1TB SSD, try to solve the problem.
But somehow even HDD didn't have any Daz file anymore, still get 100% usage on HDD while rendering (by "System") , I wonder if there some setting I haven't change can fix this?
How much system memory do you have? What you discribe sounds like you are running out of memory and renderer is using virtual memory.
Yes it is, I'm an idiot, I just realize my 16G ram all burn out while rendering, maybe is time to upgrade the ram, or is there any tech to reduce render ram cost?
My render log:
2021-07-01 00:29:37.037 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering with 1 device(s):
2021-07-01 00:29:37.037 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 2060)
2021-07-01 00:29:37.038 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2021-07-01 00:29:37.038 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 2060): Processing scene...
2021-07-01 00:29:37.083 Iray [VERBOSE] - IRAY:RENDER :: 1.3 IRAY rend stat : Geometry memory consumption: 144.794 MiB (device 0), 0.000 B (host)
2021-07-01 00:30:57.426 Iray [VERBOSE] - IRAY:RENDER :: 1.3 IRAY rend stat : Texture memory consumption: 4.045 GiB for 193 bitmaps (device 0)
2021-07-01 00:31:00.455 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : Importing lights for motion time 0
2021-07-01 00:31:01.503 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : Initializing light hierarchy.
2021-07-01 00:31:04.853 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : Light hierarchy initialization took 2.573s
2021-07-01 00:31:05.190 Iray [VERBOSE] - IRAY:RENDER :: 1.3 IRAY rend stat : Lights memory consumption: 4.713 MiB (device 0)
2021-07-01 00:31:06.180 Iray [VERBOSE] - IRAY:RENDER :: 1.3 IRAY rend stat : Material measurement memory consumption: 0.000 B (GPU)
2021-07-01 00:31:08.322 Iray [VERBOSE] - IRAY:RENDER :: 1.3 IRAY rend stat : Materials memory consumption: 918.070 KiB (GPU)
