When I want to make model higher but with a same body how can I make it?
foxyfoxfurries
Hello everyone .
My model is kid short I make her bigger but she only get bigger and more thin and stuff like this its change the shape of the model...
How can I make the model more higher with the same all taxture and not change his head arms and body shape at the same time.
Thanks =D
If you're using Genesis 8, there is a 'height' dial (shape) available in the Genesis 8 Female Body Morphs or Genesis 8 Male Body Morphs. A negative value will make your figure taller, a positive value shorter.
But you must own the following :
https://www.daz3d.com/genesis-8-female-body-morphs
https://www.daz3d.com/genesis-8-male-body-morphs
Yes I have this but when I make her taller she kind of be more thin and stuff like this , so i start to change her belly and stuff like this now she looks great. thank you :)
If you want to make your DAZ characters higher, you're going to need some 3D modeled drugs. I don't know what kind of drugs your charcters like, but mine like good old fashioned marijuana. And not any of that low poly junk from that other site either, I'm talking the high poly, subdivided, primo stuff that I sculpted myself. Just look at those vertices sparkle! Why you could almost smell it if that was something anyone had bothered to program into the software. Hey - are you going to eat that?
OK, not quite clear what you call "higher". If the "height"-dial does not what you have in mind, perhaps you talk about "bigger".
Here you can increase the scale (Parameter - Transforms - Scale) of your character and perhaps reduce the size of the head (shaping - Head - Real World - Head Propagating Scale).
You just have to play around with the various parameters. Also possible to make the torso, legs and arms longer.
I saw some taturials in YouTube and fix my character , I wanted to hake her higher because she was a little bit small , so when I make her more tall she be more thin , so I make her body with more wight and fix the other parts with some mucsle and stuff like this , now my models looks perfect! Thanks ^-^
