?como shader requests
MistaraMistara Posts: 38,675
how do i make a surface selection completely truly transparent?
no highlight catching or ghostlyness.
how do i save it as a preset?
thanks :cheese:
    i'm gonna try to figure out how to make a new matzone on an object on my own.
    there must be some kind of poly selection tool here. hmmm
    appreciating the remove unused shader menu command!
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,793
    In shader list change everything to none
    except alpha 1-100 value 0 a good idea
    drag the little shader ball into you shader browser and call it something other than no name when asked
    You can also save multi-domain shaders all at once by selecting the shading tab for your object, and dragging and dropping the multi-colored ball icon to your Shader Browser. This can come in extremely handy when you customize textures on a figure. If it's Mill-4 or earlier, select Model and then the shader tab. If it's Genesis or later, I think they call it Actor, but I could be wrong.
    edited December 2014
    Oh yeah. To use a shader, drag it from the browser and drop it onto the object. If it is a multi-domain shader for a figure, select the model (or Actor) and then the shading domain tab. Now drag the icon and drop it on the multi-colored ball at the top of the shading domain list. If the maps are a high resolution, this may take a minute as Carrara thinks about it.
    It's a good idea to go to Edit--> Remove Unused Masters--> Remove Unused Shaders afterwards.
    thanks!! :exclaim:
