Anyone know the best mirror objects I can use?
Ones that actually works as intended and gives a reflection? Has anyone used this one linked below for instance? Does it actually work in Daz Studio like its supposed to work?
https://www.daz3d.com/mirror-mirror
  • chris-2599934chris-2599934 Posts: 1,986
    edited June 2021
    It's not difficult to make a mirror that works in Iray.
    For any surface:
    • Set Base Mixing to "PBR Specular/Glossiness"
    • Set the Glossy Specular colour to white (choosing a different colour will tint the mirror)
    Leave everything else at their default values.
    ADDED: Here's a shader preset to apply those properties to any surfasce.
    duf
    duf
    MinimalMirror.duf
    173K
    400 x 400 - 131K
    Post edited by chris-2599934 on
  • FishtalesFishtales Posts: 6,235
    I use the Metal - Aluminium -Polished shader supplied with Studio.
  • richardandtracyrichardandtracy Posts: 8,195
    edited June 2021
    In the image below I simply used the chrome (recesses), copper (aperture frame) & gold (all other parts of the obalisk) metallic materials on the obalisk. Due to repeated self reflection inside the obalisk, I had to increase the raytrace path length in 'Render Settings' to 9 for all the visible area to be covered in reflections.
    So, the standard metallic shaders in the DAZ Uber category work very well as mirror shaders when applied to any surface you want. No need to buy specific mirrors unless you like the shape & frame.
    Regards,
    Richard
    Post edited by richardandtracy on
  • beachlegsbeachlegs Posts: 531
    edited June 2021
    815 x 604 - 47K
    Post edited by beachlegs on
  • lou618_2b45855fe7lou618_2b45855fe7 Posts: 65
    edited June 2021
    For any surface:
    smiley I got it working thanks..my next question to you is how do I get this effect shown below? Is it possible to make the figure in the reflection give a different pose to make it seem like its a different character?
    Post edited by lou618_2b45855fe7 on
  • SeraSera Posts: 1,675
    edited June 2021
    lou618_2b45855fe7 said:
    For any surface:
    That is editing in post. You make two scenes, one with each pose, then layer them in gimp or photoshop or whatever. Take one with the pose you want to show in the mirror, and put that under the other one. Then select just the top layer mirror area with the select tool (so you don't accidentally remove the other parts of the image) and cut or erase the image there, so that the bottom layer is revealed. If you kept camera angle, lighting, and everything else but the pose the same, they should blend pretty seamlessly.
    Post edited by Sera on
