Isn't Genesis 8.1 within the latest DAZ 4.15 Installation?
Hi,
on a new PC I wanted to continue with DAZ3D from the scratch. So I was looking for the DAZ 4.15 package on your site - NOTHING!!
Do I have to install DAZ-Central? (The onl choice)
OK, I did.
So it started DIM and I could see all packages. None 8.1
So how to get Genesis 8.1 ?
  • Richard HaseltineRichard Haseltine Posts: 111,867
    Genesis 8.1 is included with the Genesis 8 Starter essentials, it doesn't have a separate package. Install Manager is still available if you prefer to use that https://www.daz3d.com/get_install_manager/
  • AndreaswbAndreaswb Posts: 25
    Hi Richard,
    nice hint. indecision
    In DIM nothing is offered except DAZ-Central. Only after installing DAZ-Central, all the packaged appear in DIM. This IS NOT OK !!
    Please place a direct link on the DAZ homepage for direct access to DAZ 4.15 download (without DAZ Central). Everything else is not respectable.
    Andreaswb said:
    Hi Richard,
    Everything you have ever "bought" from DAZ store can be downloaded from your Product Library; https://www.daz3d.com/downloader/customer/files
    Direct link to latest DS version and everything bundled with it; https://www.daz3d.com/downloader/customer/files#prod_13176
    Andreaswb said:
    Hi Richard,
    Daz central does not appear in DIM, since they are noth doing the same job (it's just that central has a streamlined interface and reduced set of options) so I'm not sure what you mean here. You certainly do not need to have Central installed to use Install Manager.
