A way to export Surfaces values?
Is there a way to export Surfaces values of a selected object to a text file, which for me would make it faster to do a value-by-value comparison between multiple similar objects or keep track of interim settings while testing what the various settings do? Thanks!
  • AscaniaAscania Posts: 1,856
    Material and shader presets ARE text files.
  • OK, so say I have 8.1 Male and 8.1 Male (2) as seen here. I want to export the Surfaces settings so I can compare between them. In this case, I've introduced something that is annoying and I'm trying to track down what it is - but I don't want to undo all the intended changes I've made.
    443 x 920 - 82K
  • Richard HaseltineRichard Haseltine Posts: 111,908
    If they are meant to be the same then you can just select both figures, select the same surface on each in the Editor tab of the Surfaces pane, and scroll through the list of properties looking for ones with a <?> for its value.
