Heads Up: Windows 11 Will Require a TPM 2.0 Module
Nyghtfall3D
Windows 11 was unveiled yesterday and will require two components: A TPM 2.0 module and an 8th Gen or newer Intel or AMD Ryzen 2000 or newer CPU.
The TPM module in particular is causing a lot of confusion because few people know or understand what it is. I had never heard of it myself until I read an article about the WIndows 11 unveiling on Thurrott.com. MS has an overview about it but in a nutshell it protects your PC or laptop from hardware-based security threats. Tom's Hardware Guide explains why Windows 11 won't work without it and how to use WIndows to see if you have one.
MS released a PC Health app you can install to see if your device meets Windows 11's hardware requirements. Below are links to the app and the list of CPUs Windows 11 will support:
Supported Intel CPUs
Supported AMD CPUs
PC Health App - When you run the app, it may present you with a list of other options to check, including a prompt to sign in to MS. All you need do is click the blue button to check for Windows 11 compatibility and you'll get a near immediate response.
On a personal note, I'm out of luck on two fronts: My Z87-Pro mobo has a TPM connector but no module, and my Core i7-4770K isn't supported. MS will discontinue support for Windows 10 in 2025. I won't be be able to upgrade to Windows 11 unless I can buy a new PC by then, and I don't see that happening.
References:
https://www.tomsguide.com/news/windows-11-wont-work-on-your-pc-without-a-tpm-how-to-check
There is a thread on Windows 11 here https://www.daz3d.com/forums/discussion/501901/ot-windows-11-leak-and-nvidia-drop-win-7-8-support#latest
